I was given the opportunity to test the “Text to 3D” option. Something is created but I can’t see any preview images. Downloading and inserting the 3D objects into the scene doesn’t work either. What could be the reason for this? I have D5 version 2.7.1.0465. The graphics driver is up to date. Graphics card RTX A4000.
regards
Hi! I suggest you can send us your log file for checking. This post shows how to collect logs. D5 Support Tool - Get Help / Tech Support - D5 RENDER FORUM
You can share a link here or send your log to our email. (support@d5techs.com, please describe the problem and attach the link of this post to your mail)
BTW, have you checked if your network connection is stable?
This could actually be network limitations in our office. I’ll test it from home.
Thank you for the hint.
Thanks for reply. You can contact me again if there are any results.
Thank you LunaLang. It is an issue with our network limitations. Text to 3D works at home fine.
best regards
Thanks for replying. Glad that your problem has been solved.
