AI Material Capture and Plant Generation Issues in D5 Render 2.11
Issue Description:
In D5 Render 2.11, I am experiencing two main problems related to the AI features:
  1. Material Capture from Image:
  • When I upload an image, the AI starts analyzing it for a few seconds.
  • After that, it does not allow me to select any material from the image to generate a new one.
  • Even when using the default sample image that appears when opening the tool, I can visually select a material (e.g., wood), but when I click Generate, no material is created and nothing happens.
  1. AI Plant Generation:
  • When I type a description of the plant I want to create, the AI does generate a preview and a list of plants.
  • However, when I try to use Auto Scatter, I get an error and no plants are placed in the scene.
  • Instead, I only see a small blue square with a message saying that the plant generation failed.
Questions:
  • What could be causing these problems?
  • Is there any setting, update, or additional requirement for these features to work properly in D5 Render 2.11?
  • Could this be related to internet connection, GPU resources, or compatibility issues with the current version?
System Information:
  • Version: D5 Render 2.11
  • Operating System: Windows 11 Home 64-bit (Build 26100)
  • Processor (CPU): Intel Core i7-13700KF (13th Gen) ~3.4GHz
  • Memory (RAM): 32 GB
  • Graphics Card (GPU): NVIDIA GeForce RTX 4070 – 12 GB VRAM (Total GPU Memory: 28 GB)
  • DirectX Version: DirectX 12 Ultimate
  • Internet Connection: Spectrum – Wired Ethernet, 829.98 Mbps Download / 32.65 Mbps Upload
  • Ping: 22 ms
Hi @marcoc
I apologize for the inconvenience. Any AI Tool is reliant on the internet connection speed and stability. You can try connecting to another network to test if the issue persists.
  • While we do appreciate your detailed description, it’s best to include a screen recording of these issues experienced.
  • Is this problem experienced on a specific file only, or on all of your files too?
