After 2.11, not able to log-in
**D5 Render Version: 2.11.0
**Graphics Card: RTX4090
Driver Version:
**Issue Description:
Hi, I’ve got a problem to log-in after I had upgraded to new 2.11 today.
I was able to log-in before. and some of my college who didn’t upgrade yet
doesn’t have this issue.
So, I am trying to downgrade to 2.10.
(But because of Firewall issue, I’ve asked to our Tech team to unblock https://we.tl )
I guess it’s because of Firewall issue.
is there list of URL or IP address that I have to unblock from my company?
In case of Unity program, I unblocked some URL from Unity to use it in my office.
Thanks in advance.
I can’t even upload an image, probably because of the Firewall.
Hi @qsang20
  • Does downgrading to 2.10 let you access and log in to D5 Render normally?
  • I can provide you with the IP addresses and Domains to whitelist privately, please check your inbox.
Hi, there.
Today I downgraded to 2.10 and I can Log-in normally now.
Also, I’ve got your another mail including whitelists.
I will ask to our Tech team to unblock those IPs and URLs.
Thanks alot.
Hi @qsang20
Please whitelist the IPs, then if it’s convenient for you to try 2.11 again and log in.
Today, I upgraded to 2.11 after I unblocked the whitelists which you sent.
and I am now OK to log-in.
Thanks a lot.
Hi @qsang20
Thanks for updating us.
Hi! i´ve the same problem here! I don´t know how to solve this issue :sob:
Hi @estudio.dibujocad
Please send us any error prompts that appear on your end, or better, a video recording. And is it only happening after the 2.11 update?
  • You may try connecting to another network to see if there are any changes
Hi! i sent a video recording. Thanks in advance
I downloaded the 2.10 version and works!
May I know where you have sent the video? Let me know of the specifics if ever you have sent it via email, so I can pick it up right away. Or much better if you can resend it to me here via Forum’s Direct Message.
Hi! Thanks for the answer, i sent the video via Email but anyway i’ll try to share the video recording again. Can you give me an Email please? Thank you!
Just generate a link containing the video, then send it to me via Direct Message here in the Forum so I can pick it up right away.
  • You can click on my profile, then proceed to click Message
  • If you insist on having it on email, then support@d5techs.com should be fine, just make sure to have it titled ‘2.11 Clov-Forum After 2.11, not able to log-in’
