Accumulated preview loose their accumulation while using Effect - Tint
D5 Render Version:
2.11
Graphics Card:
RTX4090
Driver Version:
latest
Issue Description:
D5_tint.zip (1,3 MB)
Accumulate preview and move effect tint slider
Hi @Smolak
I’m not sure if I understood your concern regarding Tint Effect correctly, and what you expected the parameter to behave. But it basically:
  • Adjusts the green and magenta range; it can cooperate with the colour temperature parameter to adjust the white balance tone of the scene.
  • In conjunction with the colour temperature parameter, the white balance tint of the scene is adjusted by adjusting the cyan and magenta ranges.
I mean that all Effect parameters works fine with cached Accumulete preview except Tint parameter. After using it we loose final rendered ( accumulated ) viewport preview.
Hi @Smolak
This is how it looks on my end using the file you have sent.
Yes You have the same issue - Tint slider destroy cached accumulate view.
Hi @Smolak
I think what you’re trying to say is that the Tint Slider overrides the Effect Settings that you have set up.
  • If so, I don’t think it is a bug or a problem. This is essentially the entire logic of the Tint Slider, which involves adjusting the Green and Magenta Ranges. You don’t need to have the values at maximum; you need to balance them with Temperature, etc. (Just like any other photo editing software)
But only Tint slider has this behavior that reset stored image accumulated cache data.
