buenas noches…tengo una AMD Ryzen 7 4800H with Radeon Graphics 2.90 GHz…16.0 GB (15.4 GB utilizable)nvidia gforce gtx 1660 GDDR6…
EN UN PRINCIPIO EL PROGRAMA SI ME CORRIA …CUANDO TENIA LA VERSION 2.4…DESPUES INSTALE LA 2.5…TENGO INSTALADO WINDOWS 11…Y YA NO QUISO ABRIR EL PROGRAMA Y CUANDO LO ABRIA ME SALIAN MUCHOS ERRORES…INTENTO DESINSTALAR PARA HACER UNA INSTALACION LIMPIA…PERO ME DICE QUE THE PROGRAM CANNOT BE LAUNCHED BECAUSE OF DLL ERROR IN THE SYSTEM…DE AHI ME ENVIA A LAS POSIBLES SOLUCIONES PERO NO ME HA FUNCIONADO…HE INTENTADO DESCARGAR DE LA PAGINA OFICIAL DE NUEVO EL ARCHIVO DE INSTALACION PERO SIEMPRE ME DICE QUE TIENE PROBLEMAS PARA ENCONTRAR EL SITIO…LA VERDAD NO SE COMO SE PUEDE SOLUCIONAR …PODRIAN AYUDARME
Hi maxnavadf
This topic of the error that your PC gives you has already been discussed, try doing a search on the forum site, just write in the top right on search for ‘SOLUTION .DLL’, perhaps you can find the solution there, I hope to succeed.
Hi mate, you can refer to this blog and try to fix the DLL issue. Hope it helps.
