4080 super benchmark is slower compared to similar models
D5 Render Version: 2.91
Graphics Card: ASUS Proart 4080 super
Driver Version: 32.0.15.7242, nvidia driver 572.42
Issue Description: benchmark with similar models are different
Hi there,
Can you please try to click Video & Image, the time yielded on your end is quite normal and on par (with a slight second delay) with other users. The only noticeable difference is the FPS.
  • 1:16 Time is the Combination of Video and Image
  • 0:32 Time for 2k Image
  • 0:44 Time for 1080 Video
  • This user’s benchmark test is closest and similar to your specification.
Your graphics driver version (572.42) is a very recent release and is currently undergoing testing with D5 Render. In light of previous issues identified with driver version 572.16, if you are willing to try it, you can consider going back to the 560x version and then do the test again.
Also, we generally recommended to use Game drivers, but the gap between Game and Studio is usually not very large.
Hi! Thank you for the help, you were right. The only remaining question is the fps, what do i need to do, to make it higher?
Hi there,
Have you tried reverting to the 566 Driver Version? Can you have a try and do the benchmark again? Also, if you’re opening a file you can enable FPS Booster for Complex Geometry and see if it improves your FPS.
