D5 Render Version: 3.1
Graphics Card: RTX 5070 12gb
**Driver Version:**581.29
Watch the recording. I can’t use the AI features because the image flickers. Performance dropped after the update.
https://youtu.be/LRtpngqfDe4
driver update to newest version - 610.62 fixed flicking on main menus, but AI is still broken.
edit
main menu is also flicking… soo its not driver issue
edit
lower weight scene had no glitches. Its possible to rtx 5070 12gb be to weak for that scenes? before update everthing was fine ![]()
I’m having the same issue as well. Maybe it’s caused by the update?
Does this issue occur in other D5 Files as well? Please send us the following:
Log Files
D5 File
You may generate a link and send it to me privately.
same issue, after update except the viewport everything else is glitching heavily… should i downgrade to 3.0?
Please send us your log files and if it’s only affecting a single file, then please include the said file. You may proceed to go back to 3.1 after you have generated the log file.
Hi @dramarnath14 @Kenken @2xmprojekt
Can you please confirm if you’re using multiple high-resolution display monitors? If so, can you please try using only 1 monitor and see if the issue persists?
2 display - 27’4k and 22’
22" was turned off, still glitching
AI tools - broken
Hi I have some problem like you too
I don’t know how to fix it now
*GPU: RTX 4070 Ti Super (16GB VRAM)
*RAM: 64GB
*CPU: Intel Core i9-14900KF
Hi @tochipheng
We’re aware of this issue and want to collect your log files so we can fix it as soon as possible. Thank you.
I have the same issue, when ever i want to use Ai enhancer segment
having the same issues after the update. pano render that took 10-12 mins are talking 1 hour to render. I have rtx 5080. the update did something. some of my team have the menu glitch issue as well.
![Screenshot 2026-07-13 103853|690x387]
(upload://xAj5J7XKEFn69m8wNvUcVmeE4FN.png)
same issue from the loading screen itself and persists throughout the ui
Hi @thearchidyll_1 @amirul1 @tochipheng @thaslimsherif
Can you all confirm that you’re all using 2 or more High Definition Monitors? And please try use only 1 just to see if the issue persists.
It would also be best to send us your log files. Please refer to the reply I have made above. Thank you for your cooperation and we’re very sorry for the inconvenience. ![]()
i can send you the log file but the project am working is confidential and cannot be shared. does that works? and. yes tried with both 2 screen and 1 screen… problem is same… upon putting the smooth mode the flickering disappears. but ui still flickers occationally
hey, same problem after the new version, some files dont even open, goes up to 99% and the computer freezes and I need to restart everything, I have a deadline that I will not be able to deliver because of this, there´s some way to downgrade to 3.0?
Hi everyone,
We would like to inform you that we are intending to release a new build today (given that there will be no delays) to address this issue. We appreciate your understanding and patience as we work to enhance the stability of this version.
