Uploading: GP_1(4).jpg…
Добрый день, подскажите пожалуйста в чем может быть причина засветов и голубых пятен?
Hi, maybe you have to set in the effects the reflection of sunlight that forms this colored reflection of light on the objective. the Bloom and the Lens faire
Hi there. I apologize for the inconvenience this issue has caused.
Is the “Light Spots” and “Blue Stains” evident on a specific file or every file opened after the 2.9 Update?
I think you have also mentioned this issue in the previous topic you created in forum, it’s best to update or add some info in a single forum topic (if the issue is the same) so we can monitor it efficiently. Thank you for understanding. После обновления на версию 2.9 появились артефакты
You have mentioned also regarding on how to download D5’s previous versions:Historical Version of D5 can be downloaded in this forum topic Download Historical Versions of D5 Render
Could you send your log files and scene files so we can test this issue on our end? You can send them to support@d5techs.com, titled “2.9 Clov—Forum,” and briefly describing the issue. If you are unfamiliar on how to zip your log files you may follow this link: How to use Support Tool? | User Manual and for the scene files please be guided with this image.
Looking forward to your reply, thank you.
