Where can you download it? The website still has the 2.8 version in downloads.
Yes my rendering is slower now after update. Its not using full Graphic power of my rtx 4070 (only 40 % used while rendering image)
The update has already been initially released for China,and gradually to other users. Regarding performance, these would be the estimated gains
Hi sorry for the inconvenience this issue has caused. Is it the same scene file that was opened in 2.8? Which you have observed to be slower in the 2.9 Update? Let us know, thank you.
Would it be possible to collect your scene files so we may be able to test it on our end? @asisintel @solimanoculus You can send it to support@d5techs.com and have it titled ‘2.9 Clov-Forum’ Thank you~
Yes. It is the same file opened in 2.8 and rendering faster. Have mailed you the file.
Hi there, thank you for sending your files I have already tested it out. I was able to render 1 scene using 2.8 and 2.9 version, I turned off the D5 SR Beta Widget both 2.8 and 2.9 so I can fully differentiate their rendering time difference. In 2.8 the rendering time was 17 minutes 20 seconds while in 2.9 it only took 9 minutes 17 seconds thus, making 2.9 Version faster for about 8 minutes.
To ensure D5 Render run smoothly after an update, I do suggest updating your graphics driver to the latest version and closing other unnecessary files while doing the render since it also affects the performance. Thank you~
What is the capacity of ram and which graphic card did you use? I have a 32 gb ram in single slot . Does a 32 gb ram single slot perform better or a two 16gb ram double slot performs better?
thanks for your advice i must have to update the graphic driver. it will be work correctly. thanks
i changed my mind … d5 render 2.9 is impressive specially in AI enhancement and styles … yeah it’s very very impressive
Hello~ this is what I am running currently, I think my graphic drivers are behind 1 update only and I am using a 3070 laptop. As for your question, I’m not entirely sure of it but one thing I’m certain is that your RAM mHz should be the same otherwise you won’t be able to fully utilize it. My other unreplaceable RAM is 8gb while the other one is 32gb~
Hi thank you for your feedback, does updating your drivers help alleviate your issue? Mind if you share? Thank you~
Hi there, when will be available the 2.9 version for Europe? Thank you and keep going with the excellent work!!
yeah when i updated my graphics driver it’s faster than yesterday, btw i am impressed of the 2.9 because the AI enhancement now is more faster than the last version. wow great team i am glad now
out where? can you provide the link? 2.9 ![]()
Hi @xrowdac2,
2.9 is currently in the grayscale period, and you’ll be getting pop-ups for the update, but it will soon be online with full access. ![]()
I understand releasing it like this helps to catch issues. We run into the issue at the office were some people get an update for 2.9 while others don’t. Not the best while working on the same project.
Hi there, I apologize for the incovenience this issue has caused. I do suggest reverting back to the old version to ensure smooth workflow with your colleagues who has yet to receive the update. You may want to update to 2.9 Version during its official release, please refer to this link. Thank you
D5 2.9 it.s horible. it.s frezzing VERY VERY OFTEN. i have a “more then enought” station and i can.t work a very small and simple scene. DO SOMETHING. i lost already a few times my work because the random frezzing. i have major problems when i go live sync with ArchiCad , when i.m tring to place scatter, when i edit material, and of corse ramdomly when i just navigate trow the scene. PLEASE DO SOMETHING. (PC: RTX 4090, AMD 7950X , 128 GB RAM DDR5)
I apologize for the inconvenience this has caused you. Could you please let me know if you have experienced this freezing issue in other projects or only in your current one? Additionally, please confirm your sync plugin version and your ArchiCAD version.
It would be helpful if you could send a screenshot of your task manager showing both your Memory and GPU usage while running the scene. This will enable us to check for any abnormalities.
We would also like to assess your GPU status while running the scene. We recommend using GPU-Z. Please check the “Memory Used” parameter under the sensor section for better memory management.
We always advise on proper scene management to minimize the chances of lagging. In the meantime, please refer to the link below for tips on optimizing GPU usage. Thank you!
