I think it had a lag in the new version in the rendering mood, I think the version is slower than 2.8 … is that right ?
has anyone that problem ?
Version 2.9 is out?
yes, it’s out now
Where can you download it? The website still has the 2.8 version in downloads.
Yes my rendering is slower now after update. Its not using full Graphic power of my rtx 4070 (only 40 % used while rendering image)
The update has already been initially released for China,and gradually to other users. Regarding performance, these would be the estimated gains
Hi sorry for the inconvenience this issue has caused. Is it the same scene file that was opened in 2.8? Which you have observed to be slower in the 2.9 Update? Let us know, thank you.
Would it be possible to collect your scene files so we may be able to test it on our end? @asisintel @solimanoculus You can send it to support@d5techs.com and have it titled ‘2.9 Clov-Forum’ Thank you~
Yes. It is the same file opened in 2.8 and rendering faster. Have mailed you the file.
Hi there, thank you for sending your files I have already tested it out. I was able to render 1 scene using 2.8 and 2.9 version, I turned off the D5 SR Beta Widget both 2.8 and 2.9 so I can fully differentiate their rendering time difference. In 2.8 the rendering time was 17 minutes 20 seconds while in 2.9 it only took 9 minutes 17 seconds thus, making 2.9 Version faster for about 8 minutes.
To ensure D5 Render run smoothly after an update, I do suggest updating your graphics driver to the latest version and closing other unnecessary files while doing the render since it also affects the performance. Thank you~
What is the capacity of ram and which graphic card did you use? I have a 32 gb ram in single slot . Does a 32 gb ram single slot perform better or a two 16gb ram double slot performs better?
thanks for your advice i must have to update the graphic driver. it will be work correctly. thanks
i changed my mind … d5 render 2.9 is impressive specially in AI enhancement and styles … yeah it’s very very impressive
Hello~ this is what I am running currently, I think my graphic drivers are behind 1 update only and I am using a 3070 laptop. As for your question, I’m not entirely sure of it but one thing I’m certain is that your RAM mHz should be the same otherwise you won’t be able to fully utilize it. My other unreplaceable RAM is 8gb while the other one is 32gb~
Hi thank you for your feedback, does updating your drivers help alleviate your issue? Mind if you share? Thank you~
Hi there, when will be available the 2.9 version for Europe? Thank you and keep going with the excellent work!!
yeah when i updated my graphics driver it’s faster than yesterday, btw i am impressed of the 2.9 because the AI enhancement now is more faster than the last version. wow great team i am glad now
out where? can you provide the link? 2.9 ![]()
Hi @xrowdac2,
2.9 is currently in the grayscale period, and you’ll be getting pop-ups for the update, but it will soon be online with full access. ![]()
I understand releasing it like this helps to catch issues. We run into the issue at the office were some people get an update for 2.9 while others don’t. Not the best while working on the same project.
