hello i faced this problem after updating to 2.6
most of the downloaded assets lost their textures , even when i delete them and put them again
I hope you fix this as soon as possible guys
Sorry for your issue. ![]()
D5 Online Assets Library relies mostly on the internet to load. Please turn on settings such as VPN, web agency or firewall could affect the network stability.
You can refer to this post first. [Hot issue] Assets loading and downloading problem - Get Help - D5 RENDER FORUM
Currently possible solution:
- Reboot the router or switch a network for your computer (you can test by using wifi or hotspot).
- Use VPN to switch a node.
If the problem persists, please let me know.
I deleted the software and installed it again and now I have 0 problems and everything is fine
Thanks for the fast response btw the new version is amazing ![]()
Thanks for your update.
Hope you enjoy it. ![]()
