i am using default export setting, converted to editable mesh. But scale in D5 too small
Color model is fbx, white is Abc
This is a known issue. There will be size differences when imported into D5, which is similar to the problem with other formats, such as OBJ.
- A temporary solution is to change the unit in the 3ds Max system to cm before exporting the model.
blender saved the day, import fbx , then change scale to 100
