hello. I’m working on d5 rendering in real time using 3ds max sync. 3ds max turned off due to an error while modifying and modeling materials in d5 render. D5 render is already working on it. Can I run 3ds max sync and reconnect it with the working d5 render?
Or do I have to do all the work all over again?
Hi @tel8100
You can reopen your 3ds Max File (the exact file without file modification such as: Renaming, File Location Transfer, etc.) then proceed to activate the LiveSync feature again, it should retain the changes you have made in D5 Render.
Thank you very much for your reply.
