Hello, @amaan.zakir,
Apologize that this is happening to you, What D5 version you are currently using? Is this happening to all of your files? or to this specific file only? Have you used high-textured
mapping and turned on the SR feature? Also, is the attached image rendered in high resolution?
See the attached photo for your reference.
Also, could you please try to check these 2 things for me and confirm the result?
1)Disable SR to output again
2)Check the model location is far away from the origin in D5.(too far away from the origin may also result in an abnormal output effect)
Thanks
doesnt work still rippled
Hello, @amaan.zakir
Could you please confirm if you have been able to do all my suggestions and kindly answer the above questions as well? Also, is this the first time you have encountered this type of issue on your project? Lastly, Try rendering it in high resolution.
Could you send me your complete files(model files + d5 files) for testing and thorough investigation on this? Please check the reference to properly send the whole d5 folder see the attached photo.
You may send it to support@d5techs.com put the complete forum link, and tag me @maslu for easy tracking.
Thank you for your patience and understanding to D5 Render
