why is material ID in renderin channels is greyed out , and im in a crutial need of this channel , post production is a must here !
can u share all channel render image to check
all channels are available but the colour ID ( available channels are the following : Sky Mask , AO , Reflection , Transparency , Z depth )
this is weird, must be bug. have u updated to latest version. this happen with other projects too?.
can u share ur scene on wetransfer, iāll check on my side.
the file is one wapping 8 GB , and where i live , it will take 10 hours to transfer the file , anyway yes i have the latest version 2.6 and im a pro member as well !
donāt know if this helps you out , the file have been transfered from rhino to 3ds max , and from 3ds max to d5 , long conversion , but it works .
the 8GB file size is not due to the large scene , i think itās due to the long conversion , from rhino (nurbs ) to max (mesh)
is this happen with other projects too? or happening with this one only.
Iām guessing you turned on line draft mode in the post parameters
Hi @salehelio3
Please check if you turned on theāāOutline modeā', and try to turn it off and see the results.
Regards,
this is solution. i have cross checked. when outline mode is enable, material id channel get disable.
Same here!
Why does outline mode prevent outputting the material ID map?
Hello, it is not yet supported to output Material ID channel maps when using outline mode, so the Material ID option is greyed out in this case. Thanks for your understanding.
