White lines & bright reflection in mirror
Hi there,
Any suggestions on why there are white outlines in my render? Particularly where the floor meets the wall and around the bottom edge of each piece of furniture? Also, why there is such a bright reflection in the mirror?
Thanks so much for your help.
Hello, would you mind telling me which version of D5 you are currently using? Also, what modelling software are you using? You can check your model for any resurfaces or gaps. Also, it is recommended that you update to the latest version of your graphics card driver.
Thanks for you help. I did review my model and found the issue. Thank you. :slight_smile:
Thanks for feedback!
