I cannot make this grass white. Even when the base color is set to white, it stays green. I’ve tested different hues which work, but not with white. Please help.
Text
Hi, you have to play with the material, you have to remove the green texture and put a map with a white background, see the drop-down image of the material and its values that I put, instead the color must be white
I’m sorry - I just realized my values did not match yours. It works now, many thanks to you sir!
