Hi @NOG_the_DOG, can you send us your scene files so we can test it? You can send it to support@d5techs.com and have it titled “Clov-Forum White Glow around building” Thank you.
Hi there. We have not yet encountered a report in which the D5 SR Image Rendering Widget is causing issues. I also tried it on other files, and it is working fine. Does it only occur in this specific file, where the white glow is also evident? I look forward to testing your files. Thank you.
I tested your file and adjusted the “Highlight Local Exposure” around 0.72 and it seems that the white glow outline disappeared, and if the value is set to 1 it is much more prominent. You may want to try adjusting this parameter and see if it is also effective on your part.
Despite the workaround for this issue, we want to further assess why this is happening. Can you also send us a link or the image of the Custom HDRI that you used? Thank you so much.
