When starting D5, Vectorworks crashes
Dear Support Team,
When i starting D5, Vectorworks crashes.
Could you provide help or some advise at this point.
https://youtu.be/vs-67ynjqu0
zziplog.zip (2.2 MB)
Hi there, I apologize for the inconvenience. To better understand the situation, I will be asking you a few questions:
Also, the video you provided seems to be private, and I can’t seem to access it. Looking forward to your reply, thank you.~
Thank you for response.
Sorry about video link, my bad. Now it is open u can check.
What is your D5 Render Version and Livesync ver?
•⁠ ⁠2.8.0.0471
Is the issue also occurring in other files? or is it file-specific?
  • d5 files saved earlier are opened, but I can’t livesync
Hi there. I apologize for the late reply. You might want to try reinstalling the D5 Livesync plug-in and see if it alleviates the issue, but can you also provide your D5 Livesync version to ensure it is up to date? I will also be forwarding this to our team to see the underlying reason why this issue persists. Thank you so much~
Hello Clov.
D5 Live Sync For VectorWorks version is 1.1.0.0016.
BTW, I tried all the reinstallation options. I even reinstalled Windows 11 again, and then VectorWorks, then D5. It didn’t help. I bought and increased the RAM. It didn’t help again.
I am curious about how much D5’s work depends on the AVX settings in BIOS?
Now I found another thing.
I did a test on the Vectorworks version 2024 all works fine. Problem is with the Vectorworks version 2025
Hello thanks for updating us regarding this issue, and I apologize again for the inconvenience this error has caused. Our team is currently investigating this issue further and is working on it. Thank you so much~
Cloc thank you for provided update/
I have checked, same issue.
Please check video - https://www.youtube.com/watch?v=Kva4n2mx4VQ
this is new log file
zziplog.zip (3.1 MB)
Hi, sorry for this. Have you tried uninstalling the old Livesync plug-in first and then installing the new one we sent? If so, we might need to investigate this issue a little further. Thank you for providing us with your log files. We’ll update you regarding this matter. Thanks again!
