When I sync the file to D5, the objects are combined in one object
Hi, support.
I am using Cinema4D.
When I sync the file to D5, the objects are combined in one object.
Is there any way to solve this problem?
Hi @yosa,
Model files will be defaulted as a whole (without layers and hidden parts) when imported into D5. If you want to edit different parts singly, you can divide them into different model files and import them to D5 separately. You need to differentiate the materials in the modelling software at first and can reapply textures to them respectively after importing.
Regards,
