New and improvements
Widget
Advanced Image Rendering
Advanced Video Rendering
VR beta
Stage Light
Color Grading
Rendering
D5 GI takes a step further with global illumination accuracy
Orthographic view image rendering
Adjustable sunlight intensity in Geo & Sky
Feature
Auto-Save
Language Setting: English and Chinese
Direct import of SketchUp 2021 files
Adding d5a models grouped with lights to local library
Beginner’s Guide
New shortcuts for switching render quality, display mode and navigation mode
LUT effect preview available on hover
Optional channel map rendering
Rendered files naming improved
Model/Material Selecting Tool improved
Animation camera curve improved
Display of system information
Productivity
Enhanced Smoothness
Improved archive stability
Improved NAS I/O
Alert on insufficient capacity
Assets
- Added Customizable Assets
- Supported changing clothes for static Character models
- Supported choosing lights on/off, driver, and car paint color for Vehicles
- Supported scaling and other adjustable parameters for Particles
Added 2D Character assets
Supported filtering dynamic models
Supported Favorite for Particles
Supported Favorite and Recent for Brush, Eraser and Path
HD tags on high-poly assets
Optimized “Aligned to Terrain” to draw on any surface
Optimized Asset Library interaction
- Recent list supports up to 60 records
- Support category expanding/collapsing
- Optimized page number position
Fixes
Unable to select certain models after scaling or flipping
Some invalid shortcuts
Errors of some archived lighting
The update issue when assets are attached to main models
Unexpected orientation change of brushed vegetation when reopening the file
Grass material out of model
Loss of opacity map when a .d5a file is saved to local
A random bug that Asset Library needs redownloading after updating D5
Detailed introduction to some functions
Widget
D5 Widget is a customized extension module of D5 Render, aiming to provide advanced features while keeping the simplicity. (learn more about D5 Widget)
Go to Menu > Preference > Widget, and you can check what you installed, switch on/off with one click to manage your widgets.
1. Advanced Image Rendering
- Select .png .jpg .tga .tif .exr when rendering images, with channel selection enabled.
2. Advanced Video Rendering
Select .mp4 or .avi when rendering videos.
Sequence of frames supports .png and .exr with channel selection enabled.
3. VR beta
Explore the scene with Virtual Reality, available for SteamVR-ready devices. (e.g. HTC Vive, Oculus Rift…)
4. Stage Light
Navigation Bar > Add Lights > Stage Light
Support customized Gobos and Haze effect
5. Color Grading
Precisely control the tonal values of Midtones, Shadows, Highlights, Global in the scene with Effect panel.
Rendering
6. D5 GI takes a step further with global illumination accuracy.
- Advantages of various rendering techniques are integrated in D5 GI. It combines raytracing and efficient light caching to optimize algorithms for different scenes. Consequently, D5 GI offers a result close to Ground Truth within milliseconds, which allows a simplified rendering experience without further processing. In 2.1, D5 GI takes a step further with global illumination accuracy. With real-time performance and near offline quality, D5 enables you to achieve photo-realism in the blink of an eye. (learn more about D5 GI)
7. Orthographic view image rendering
- Image rendering is supported in orthographic view.
8. Adjustable sunlight intensity in Geo & Sky
- In Geo & Sky, you can click on the three dots and adjust the sunlight intensity.
Feature
9. Auto Save
Auto Save setting is in Menu > Preference > General. This widget is enabled by default, and you can set the auto-save interval manually.
Go to Menu > File > View history version, and you can open three most recent projects that were saved automatically.
To configure Auto Save, please save the project first. Auto Save will not be activated until the projects are saved.
10. Language Setting
- Interface language can be changed in Menu > Preference > General. English and Chinese are supported.
11. Direct import of SketchUp 2021 files
12. Adding d5a models grouped with lights to local library
- After grouping d5a models with lights, you can find the group in the resource list. Right click on it, and you can add the group to local.
13. Beginner’s Guide
- Go to Menu > Help > Beginner’s Guide and check the page to quickly learn about the layout and features of D5 Render.
14. New shortcuts for switching render quality, display mode and navigation mode
- Shortcut F1 / F2 / F3 to switch between high/middle/low preview quality.
- Shortcut Alt+V to switch between Orbit and Fly navigation mode.
- Shortcut Alt+1 / Alt+2 / Alt+3 to switch between Lit, Wireframe and Clay Model mode.
15. LUT effect preview available on hover
16. Optional channel map rendering
- When rendering images, you can check the channel maps you need to render on the right of Channels Option.
17. Rendered files naming improved
- We have improved the naming rules for rendered files. Output of image, panorama, video render and render queue is named in the same format: D5_[Image/Panorama/Clip]_[Timestamp]. Clip names will be kept in the rendering queue to make sure the output matches with the clips for easier management.
18. Model/Material Selecting Tool improved
- Selecting tools are now merged. We also improved the coordinate axis and clickable area.
19. Animation camera curve improved
- We further improved the calculation of angle change in camera movement for a smoother transition.
20. Display of system information
- Go to Menu > Help > System Info or click on the left bottom of Welcome Page to check the system information of your device, including graphics card, driver version, etc.
Productivity
21. Enhanced smoothness
- D5 GI and reflection efficiency was boosted 2-4 times. With an advanced mesh rendering algorithm, we saw a 100%-200% increase in the FPS of complex large-scale scenes after optimization.(learn more about D5 Smoothness)
22. Optimized archive stability
- We optimized the read-write method for 1.save files and improved project I/O stability.
23. Optimized NAS I/O performance
- D5 Render now supports project file storage of network attached storage (NAS).
Assets
24. Added customizable assets
Supported choosing car paint color, lights on/off, and driver for Vehicles
Supported scaling, speed adjusting and concentration for Particles
25. Added 2D Character assets that are:
- able to receive lighting data
- applicable to different scenes
- always facing the camera
26. Supported dynamic models filtering
- Select “Dynamic only” and you will see all the dynamic assets in Asset Library.
27. Supported Favorite for particles
28. Supported Favorite and Recent for Brush, Eraser and Path
29. HD tags on high-poly assets
- In Asset Library, assets with an HD tag on the top left are high-poly assets ideal for close-up shots.
30. Enhanced “Aligned to Terrain” to draw on any surface
- Brush is capable of identifying the model normal of any angle, making it easier to create green walls.
31. Optimized Asset Library interaction
Recent list supports up to 60 records. Now you can find more assets that you used in
Recent and easily search for them. -
