hi guys… quick question… what is the max limit for 3d faces it can handle per file.
thank you…
thank you…
Hi! Do you have any problems with this your rendering? Maybe describe the specific issue and we will try our best to help you.
hi Luna… any idea the MAX no. of face it can handle?
Hello! Different scenes may have different limits. This is related to your model as well as the textures used.
D5 also uses Unreal Engine under the hood, so expect good performance. Your computer hardware and scene complexity will determine what the software can handle.
thanks Guys… appreciate it… was thinking if there is a number that say… Faces 500,100,000
literally
The limit I think is related to the hardware not the software, however, with 500,000,000 faces, if you have good hardware, you are far from the limits!
In the image I enclose, D5 is handling almost 3 billion faces ( 2,812,654,140 )and the Video Ram is occupied at 52%.
The limits related to your model as well as the textures used. At the same time, if the model has too many faces/the model is large, you also need to pay attention to the usage of dedicated GPU memory.
thats effin lit
loud n clear 3 billion will be my marker… thanks mr.expert for dropping this info.
thanks man…appreciate it.
