Hello D5 Team! Just wanted to say the update for 2.6 was brilliant. But every time when i tried to change to D5 water material, this happens. It happens for almost every water material template in the library. Can we get this fixed ASAP? thanks!
same problem, and it should work with a plane without the need for extra thickness.
Sorry for your issue.
Is your model’s water surface Normal orientation correct?
