No matter what water material I use it will never get darker than this (see slider.)
Also, the refraction wont change at all so there is too much reflection from the busy wall on the water. Any help is appreciated
Hi there. I am here to help. You can try modifying the “Base Color” and setting it up in a darker tone.
As for the refraction slider, have you tried restarting your D5 Render application?
I tried to recreate the scene or environment you provided, and the refraction seems to work. May I also know the following software version that you are using?
Thank you~
All of that worked. Thanks!
