Open a empty scene D5 Render 2.9 took 5GB Vram, is it normal?
hi @jackieteh , i noticed when wind, dinamic objects and dof are enabled, more vram is used
my files are ver vram consuming so a try to keep this off
Hi there,
Are there any other applications opened while accessing the Task Manager? This was my VRAM value when I opened D5 Render with Google Chrome.
Yes, i open 3ds max to live sync d5 render, if this is the issue, is this mean live sync is not recommeded to use in my case?
Hi there,
Not really. What I meant to say was that I think this is within expectation. It certainly has a slight difference from the old D5 Version (2.8) since 2.9 has integrated the terrain, hence adding to the VRAM’s usage. ![]()
