Hi after updating to 2.5 my video texture is not loading. i cant see them on my objects. Please suggest something
Hi mate, can you tell me the texture format? also, Is the face you apply reversed, ovelayed?
Does it still happen after rendering? Do you open the real-time mode?
yes. its in real time and with .mp4 format. this is the same texture which i have been using. geometry is ok. i’ll check again and will inform you.
Sure, if the problem still happens, can you send the scenes or mp4 to us for troubleshooting?
support@d5techs.com
sure. will send you
I am facing the same issue. Can you please help? Sending you file and texture
Hey Bruce, Sent you video texture through we transfer. Please check.
Hi mate, we opened your files then inserted the video and saved it. The problem was not reproduced.
To confirm, does the problem happen when you sync the file again to 3ds Max? Or did you launch D5 Render from 3ds max directly?
Regards,
Oliver
Hello there, i been having the same problem. Video did work anymore.
even video that already resulted in a previous version.
Please let me know how to fix this
Hi mate, is the video in a network path? If yes, please move the video to a local place, then insert it into D5 Render.
We are going to fix this problem in the coming 2.6 version.
