i rendered Video, after complete and finish rendering, it dont plays
Hi george, I saw the post in FB community, it seems the render was not successful but I am not sure why, if possible, please send me two folders that contain logs:
- A folder called logs, in the installation directory of D5 2.1
to my email ziyin.zhu@d5techs.com
Thanks Oliver, i sent it on this mail. but i have another problem too. i am so tired to get render of my project. i work on project for challenge already 2 months. i started few days ago rendering step by step, but from yesterday when i opened D5 and try to continue rendering, it dont starts. i have not idea what may would be resson. can you help me?
Hello georgemelkadze, before it comes to 1%, it needs some time to render static frames for the video, so it may take some time. If you turn on DLSS, and removed useless items in the scene, it should be faster, could you please try it?
Yes, i tried. Until now, it needed 20min -30 min for starting , but now after 4 houre waiting it is still on 0%. I also reduce size of model and reloaded it but problem did not solve.
Hello, could you let me know how large the file is and what graphic card you use? Besides, maybe the clip is long? Try dividing them into several parts then render again (those clips can be duplicated), also you can render low resolution(480p) to see whether it can render.
The file(model) size is 4gb. I was rendering it perfectly during some days. At first, i imported whole model in D5 because i need render full view of model. As i said it worked perfect and i rendered some scene from it. After this, 2 days ago when i opened it again and try to render, it did not start. Then i reduce the size of model (from 4gb to 900 mb) but it still dont starts rendering. Duration of scenes are 10-15 second.
I want to finish it because i worked so hard but dont know what to do.
Graphic card rtx 3060 12 gb
Ram 32 gb
I7 11th gen
Hello georgemelkadze, do you still have this file?
Please let me know its file size, resolution and length if you still have it or remember that.
We are looking into this issue and we have received the logs file you sent, thanks.
Ahh… sorry i dont have it. I deleted this one. As i remember the length was 50 second and size of this file was 800mb (2K quality)
