Video Matching
It would be nice to have a feature similar to that of blender where we can MATCH OUR 3D MODEL WITH THAT OF A DRONE FOOTAGE and render it in d5
WindowTop works well for still image photomontage but it is a guessing game for the focal length.
Using other software I can set the focal length (not FOV) which I can find in file info of Photoshop on any camera. Usually gives a 35mm standard ratio/comparison.
If D5 could allow setting the virtual camera with that information, focal length, then positioning the virtual camera using Windowtop and WASD_EQ keys in D5 makes it very easy.
The trick to camrea matching is to have the virtual camera set to the same focal length as the physical camera.
Now if you want to get it on, something like Syntheyes can output tracking points and a virtual camera that software such as EIAS 3D has been doing since 1995.
If D5 could use this data (sure it could) then camera matching your 3D model in D5 to drone footage would be a reasonably simple task.
I have asked the same of Lumion and Twinmotion for years but no avail.
Of course, UE5 will do it. It would be awesome if D5 covered that aspect of ArchViz. Game changer right there!
Hi, the coming D5 2.4 version will be able to set camera focal length, but I am not sure whether it is 100% consistent with Photoshop.
Agree, this should actually be one the main priorities for D5 to implement ASAP. Was just about to request this and then noticed you already did. Really good shout!
Good to know focal length settings were added! I’ve been experimenting with it for drone matching, and while it’s getting closer, a native ‘Image Overlay’ or ‘Match Photo’ feature like Lumion has would be such a game changer.
We’re seeing an increasing number of requests to insert project videos into drone footage. This tool needs to be developed so we can match camera paths. This feature is currently missing from my DaVinci Resolve workflow.
I assume this development goes hand in hand with the photomatching feature for photo insertions, which is also lacking. Thank you. Your software is fantastic; it’s almost perfect.
