how can you change the aspect ratio with a camera movement template please (360° pan) ?
Hi there. Currently, you cannot modify a clip’s aspect ratio when the animation template is integrated. However, you may modify the camera’s aspect ratio, add the clip and select your desired Camera Movement template again (repeating the process).
Note: I am using the Advanced Camera Tool Beta
Hope this helps, thank you.
Hi there. Yes, that’s what I discovered last night. Maybe this will come in future versions. Thank you !
