Version 3.1.1 D5 Replace from Asset Problem
D5 Replace Asset Problem
I have a problem with Replace Asset in the new D5 version.
My workflow is:
Rhino → Export to D5 → Import → Sync Coordinates → Replace with D5 Asset
This worked perfectly in the old D5 version. When I replaced a Rhino trees with a D5 trees, it stayed in exactly the same position.
Now, in the new D5 version, when I replace the trees, they move to another location and all the trees get overlap in the same place .
I also tested with simple rectangles in Rhino, and they move after replacing them with a D5 asset too.
I even opened an old D5 project where everything worked correctly before, but the replacement now has the same problem.
Is this a bug in the new D5 version, or is there a new setting I need to change?
Thanks!
I also tried downgrading to the previous D5 version, and the Replace Asset function works correctly again.
So it seems to be an issue with the new D5 version.
Has anyone else experienced this? Is there a fix or a setting I need to change?
Thanks!
Hi @razeen.nazar
This issue should be fixed in 0758, it can e accessed using this link: Download Package
Hi, thanks for the link.
