Hello D5 Team
Turning this option on and off currently has no changes.
My water is still repeating and can’t be fixed with uv random.
Please help me.
Hello D5 Team
Please help me.
Turn it off and on again, it will work
I have tried this several times, and even closed the file and reopened it, but it still doesn’t work.
Hi there, sorry about this issue. Which water material did you use, or did you simply use the Material Template for Water? I have tried to recreate the environment where the problem was noticed, but unfortunately, I have not encountered it. Can you perhaps provide me with the parameters of this water material or send the file? You can send it to support@d5techs.com and have it titled 'Clov-Forum" and then just briefly describe the issue. Thank you!
hello @Clov , have a nice day.
thanks for your support.
i used the “dark blue pool water” material from the material library.
due to project security reasons, i can’t provide wider image captures as it might affect copyright.
but i’m happy to have fixed this bug, after restarting my computer and reopening the file, everything seems to work fine.
Thank you so much for sharing how you were able to resolve it!
