[Urgent] D5+Vectorworks Issue!
Hi, I have encountered a reoccurring issue that I cannot seem to figure out. I am not well versed with these kinds of programs, so it may be something minor however it has caused me to fall quite a bit behind with my work.
Issue: When I am synced with Vectorworks and enter the edit mode in D5 all the textures become f**ked up (photo attached below) then the only thing that seems to fix it is to delete the extrude and remake it. it is easy to enter the edit mode by accident and there are many separate extrudes.
any help would be appreciated as I am in great need.
Both operating systems are up to date and the device running them is plenty powerful enough to run them.
Thank you in advance
Hi there,
I apologize for the inconvenience this issue has caused. Have you tried using D5 Render Textures on these surfaces? Do they also have an abnormal UV Map?
Would it also be possible for you to send us your VectorWorks File and D5 Render File for us to test on this issue? You may send it to support@d5techs.com and have it titled " Clov - Forum D5 + Vector Issue "
Thank you.
Thank you for getting back. The materials are imported, however, the issues still occur with built in ones.
The mapping does not seem to affect it.
I can send the file if it is the only way that the issue is going to be resolved.
-Shea
HI there,
Please do and let me know. Thank you.
