Hello
i’d like to know, in video clips, i have some animations.
But if i update some objetcs, like position or visibility , they stay the same in clips. Is it possible to update everywhere ?
For exemple if i don’t want anymore any of one object, to remove frome every clips ?
at the moment i have to do it manually in each clip
thanks
no i don’t understand.
whatever i check transition animationtrue or false, if i disable the eye for a scene or a clip, then update scene, if i switch toanother scene or clip it do not change in all my scnes or clip.
i have to do manually in each clip…
hi @kana ,
each clip is independent and currently needs to be processed one by one.
or make a copy of an already edited clip.
We will consider adding the ability to apply parameters to multiple clips
ok thank you
