Like the title suggests, I am unable to change my “Asset Storage” location. My team has a server that we store all of our projects/assets on, so we’d like to be able to create a centralized D5 Workspace on that server.
We’ve successfully been able to change the asset storage location for one PC; however, our other PC has been unable to change this. Is this a current limitation to the software in that there can only be one workspace per PC? Are we unable to share the same D5 Workspace?
I’ll include a screen snip below of the setting I am talking about. The issue is that when I try to update the location, nothing fills the “New Location” box and the confirm button always stays in that greyed out state.
The other PC updated the location on first try and we were able to click the confirm button. Not sure what could be causing the issue. I have already reinstalled a fresh version of D5 Render on the problematic PC, but that didn’t seem to fix the problem.
After some more trouble shooting on my end, I found a solution. It seems that the issue was caused by us using the same D5 Render Pro account on both PCs. When attempting to set a new “Asset Storage Location” using our second Pro license, we were successful.
Before, we were using the same account on both PCs and just signing out when moving between the two. Everything is working smoothly now that we have two separate licenses pointing to the same folder location.
Hopefully other people having a similar issue finds their answer here.
Hello Brendan, sry for the late reply, we did a test and found it may not work as you described, because we do not set limitation on the file store location according to D5 accounts.
Since you mentioned you store the files in a server, I think you may enter a Relative address like this:
\10.xx.x.xxx\folder\files\xxx
which is not supported.
You should map your network drive to your local computer, then select the path like this in D5:
Z:\xxx\xx
Then it should work, no matter whether you have Pro accounts.
For reference, Map a network drive in Windows (microsoft.com)
we’ve got the same problem. we’re unable to change the location to a network-path.
d5 doesn’t show mapped network-drives but on the other hand i’m able to choose
a relative address, which i can’t confirm at the end.
No, we do not set any limitation for that feature for free account, please do not worry.
I think it is still related to the network path.
As you mentioned, when you choose a relative address, the Confirm button will be greyed out.
But if you map the network drive correctly, D5 should recognize and be able to use it, please check this:
thank you oliver for your reply,
so in the meanwhile we subscripted to the pro-service but the problem is still the same.
the network drives are mapped with the windows on board service (no 3rd-party tools).
perhaps is there an issue with windows 11?
i got it!
here’s the solution for other user:
add a new registry-key (d-word 32-bit) under “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System” - named “EnableLinkedConnections” with value 1.
if it’s still not working install the “SMB 1.0/CIFS file sharing support” in the windows features.
and don’t forget to restart your computer after each configuration!
Hello, I know this is an old post (Considering, how fast you guys improve the software), but I have a similar issue. We are trying out D5 Render and would like to share our assets library with every workstation in our design studio. Well, it’s mainly a shared material library that we need (Using our NAS server) and since it’s not possible to export material with its adjusted parameters (etc. scaling woodcladding correct) We would like to have a shared local library. (Based on this thread, it looks like it’s not officially supported…)
Anyways, I have tried to do the current solution, which was to add EnableLinkedConnections and activated SMB 1.0, which has not worked for us. I have added our NAS to the Z:\ drive, but when I try to change to asset folder to the shared library, it’s just greyed out, with a red message: “Duplicated filenames in the location. Please select another one.”
Hello mate, maybe you select the folder inside the one which should be selected, so that error message will appear.
Please try creating a new folder there, then set the folder to be the storage place.
