TV assets with blank screens
Could we get some TVs that have blank screens? I know some would rather not see a black screen but a black screen looks much more realistic than one with a bright image and the label QLED TV or SUHD TV.
Thank you for your consideration.
You can change the screen material on your TV to black.
if u mean like this
Yah, I had to play with my TV screen and got it more or less realistic. I am not sure why D5 doesn’t provide the basics before getting fancy.
Ok, we will record this need. By the way, you can delete the map and turn off emissive option, then change the material template to Transparent, I think the TV will look more real, with blank screens…
Also if we can get TVs without stands so it can be wall mounted?
Hi there,
I’m running the latest D5 version, but somehow can’t change the material or delete the map.
Can someone explain to me how to do it?
Hi mate, can you screenshot or record a video to show the problem? Are these materials and maps from dynamic assets in the D5 library?
Hi Bruce,
thanks for the reply.
I found the way to do it.
Thank you.
Thank you for your update.
