I am new to D5 render, and trying to learn how to use the true displacement feature with included D5 pro textures. When I switch to displacement mode I notice that the height map section is empty. What should I use for the height map section, or how do I make one?
Some materials in our online asset library come with built-in height maps, while others do not. If the assets you’ve used lack a default height map, you may need to import one. You can take a screenshot of the material and use an AI tool to generate a height map.
