Tree not showing up - Cannot remove it from path
Hello there,
I am not sure how to solve this weird issue I am facing.
This tree is not showing up suddenly, and I cannot even delete or remove it from Path settings.
Restarting the D5 did not work.
I have not tried deleting the F2 folder yet
i
Hi @nima.mousavi9
Is there a way you can identify which specific vegetation model is not appearing?
  • Which version was this file created in? And which version was this opened?
  • There’s a possibility that this model was replaced in the newer version.
  • Or perhaps there’s an issue with this specific model that may need immediate repair (so we need to know the specific model)
Hi @Clov
Unfortunately, I do not have any old images that show the asset.
It is created in the latest version and opened in it, but if it helps, I have to note that I had some problems with clips crashing, and you mentioned updating my GPU driver, and it solved that issue. I am not sure, but maybe after the driver update, it is showing like this.
RTX 3060 TUF ti
Hi @nima.mousavi9
Thanks for your update. I don’t think this has anything to do with your recent action regarding Driver Updates, since it will only impact performance-related issues and by no means D5 Render Assets.
  • Are there no update buttons present which will prompt you to update the assets?
  • Was this file created in previous versions? And was it opened in the latest version you’re using? Chances are, this particular asset has been replaced with a better one.
  • If you can’t determine this particular asset, you can send the file to us so we can open it in earlier versions and check which specific vegetation object it is.
