안녕하세요 d5렌더를 아주 유용하게 쓰고있습니다 이번에 LED 영상 관련 일을 하고있는데 멀티미디어 기능 영상을 재생할때 너무 번져서 혹시 해결 방법이 있을까요?
Hi @lnp6610
Have you tried using D5’s material template - Multimedia instead of changing the texture image in SketchUp?
Yes, in sketchup, I only set the texture image size, and in d5, I played the video using multimedia.
The media is played using multimedia, and there is a blurring phenomenon when the video moves.
Hi @lnp6610
May I know the video quality you have used? Have you tried increasing the quality?
- Additionally, if it’s possible, can you send us your D5 File? Or perhaps your SketchUp file? Just the portion that was affected. You may send it to support@d5techs.com and have it titled ‘Clov-Forum 멀티미디어 색번짐’ then try to include the forum link. Thank you.
Hello, I sent you the file by email. Thank you for your quick response.
Yes, I shared it!
Hi @lnp6610
Thanks for sending your file. I just tested it and tried to place a basic plane and inserted multimedia into it. It seems that the blurring effect is due to how the model (surface) was set up, which is separated into individual slats. Perhaps modifying the size of these slats would greatly help with the quality. Nevertheless, I will also convey this requirement to my team to see if this is something that needs more optimization in the future. Thank you~
I’ll provide the video link: Unique Download Link | WeTransfer
Yes, thank you for your quick reply. If the individual models are not blurred when updated, I think it will be useful for other tasks as well. Thank you~!
