자산에 있는 재질을 적용시 안보이는게 몇개 있습니다. 왜 그런걸까요?
테스트 하는 이미지중 보도블럭 재질이 있는데. 텍스쳐가 보이지 않아요??
방법이 없을까요?? 다른 것들도 가끔 그러던데… 해결법좀 알려주세요.
Hi, try removing the Super Resolution that was on the dropdown at the top of your left, and verify that the texture scale must be smaller.
Also check for graphics card update
Hi there,
I apologise for the inconvenience this issue has caused you. Aside from @riccardofortelli’s suggestion, may I know the following:
  • Which 3D Modeling software you are using? Have you tried replacing its surface and reapplied the D5 Material?
  • Does this only occur in this specific file? Or is it also evident in other files as well?
  • If possible, can you send us your file so we can also test it on our end? You can send it to support@d5techs.com and have it titled “Clov-Forum Material Texture not showing”
여러가지 알아봐줘서 감사합니다.
3ds max를 사용하고 있고, d5에서 재질이 표현되지 않았던거는 max에서 모델링을 하고 uvw map을 적용하지 않아서 그런거 같아요. max에서 uvw map을 적용했더니 d5에서 재질이 적용 되네요.
Uploading: 화면 캡처 2025-01-20 104527.png…
Uploading: 화면 캡처 2025-01-20 104553.png…
Hi there,
Thanks for updating us regarding this issue, glad it was resolved on your end.
