why i can’t render a top view in high quality?
Hello, could you show us a screenshot or send the sample file to me for testing?
Hello, I am working on a project for a client that needs a top view, apparently the high quality does not work for me as soon as I put the view on top.
I send the top view in high quality and I send the perspective view in high quality so you can compare
Hola Carlos!
No estoy seguro de los resultados o efecto que estás buscando, pero si me permites darte un par de consejos:
- Reduce al mínimo el FoV, (actualmente no se pueden renderizar vistas ortogonales)
- Apaga el sol, para suavizar las sombras.
- Aumenta la intensidad de la luz del cielo.
¡Saludos!
Gracias Amigo. lo revisare
Hello, in the preview mode, the glass looks white, but in the final renders it will appear normal, you could give it a try. I also escalated this problem to our dev team, we will fix it soon, thanks.
