I have a problem moving objects while the view is in orhogonal mode from Top.
It happens, while I touch the object, it flips of 180° upside-down. Then I can move the object…but it’s flipped, I have to manually rotate it of 180°.
It seems, while I touch the objects from top view, the gizmo automatically triggers the rotate command and rotates the object of 180°.
Regards
