Hello, one of the hedges most often found in France and Europe is the thuja hedge… I can only find one occurrence in the library by searching for thuja, and that’s the tree. That’s fine, but if it’s possible to have Thuja hedges, that would be perfect, thank you.
Hi, try this Thuja hedge which is in SKP, if you know how to use the SKP graphics program you can also resize it to your liking, or import it into D5 you can also do it in the rendering engine
If you are not satisfied, just do some research on the web, as I did, you will find several sites that have this type of hedge
Oppure, puoi usare il programma D5, cioe crearti un parallelepipedo con dimensioni della Or, you can use the D5 program, that is, create a parallelepiped with the dimensions of the hedge with a material that you can subsequently make transparent, lay down in D5, find the Thuja plant in the library and with the brush at maximum, as you will see in the image, insert it then the make the material that you used to make the hedge transparent, this is a way to overcome the obstacle, until D5 places it in the bookcase.
Sorry for the English
you are right but,
The sketchup hedge can do the job, seen from a distance…
but I’m sorry that on my favourite software, which offers so much beautiful vegetation, I can’t find this standard.
I’m already subscribed to so many 3d extensions that I’m reluctant to buy my thujas from another site, I’d rather buy my daughter a cake for that price.
I think it’s within the reach of D5 developers.
in my business I never use these 44 models added recently by D5
(which are very beautiful, by the way)
You’re right about your daughter, they come first.
What graphics program do you generally use?
sorry for this late reply,
I use sketchup, D5, v-ray and Photoshop
