The buildings facing south in Rhino are rotated by 20-30 degrees in d5. Therefore, even though it is 12 o’clock, the direction of the sun is not correct. All the images in the examples are at 12 o’clock.
+)After creating a ‘Scene list’ in the top view and working on it in d5, sometimes when you check it later, the scene list has changed to one with the north-south direction reversed.
Hi there,
Just to confirm, the rotation is caused by D5 Render and was it intentional right? Or did you set it up that way? Have you tried adjusting the North Offset to 0?
Can you send us your Rhino and D5 files so we can test them on our end? You can send it to support@d5techs.com and have it titled “Clov-Forum Problem with the direction of the sun”
