Every time a file is turned off and off, the position between modeling and asset is incorrect
So I can’t use both the scene and the asset, how do I solve it?
Hello. Sorry to hear about your problem. Which version of D5 are you currently using? Which modelling software are you using? Did you use a plugin to sync the model to D5, or did you import it directly?
Did your misalignment happen after updating the model? If this is the case, refer to this post: Why do models become displaced after replacement/update? - User Manual (gitbook.com)
