Hi guys! I don’t know if it has happened to anyone else but I have a file that won’t let me get the final render and I get this message " Out of video memory trying to allocate a rendering resource. Make sure your video card has the minimum required memory, try lowering the resolution and/or closing other applications that are running. Exiting…"
I apologize for the inconvenience this issue has caused. I have a few questions regarding your PC Environment and the issue you are currently experiencing, please send us the following images.
Memory Speed
System Information
VRAM - While opening your D5 File
Which D5 Render Version are you currently using?
This issue is usually evident when you have used a lot of assets in your D5 Render file without proper asset management. If any Procedurally Generated Vine assets were inserted and created in the previous 2.9.1 Version and you have opened it using 2.10, please tryo to change the parameters and lower them.
