The Ai enhancer its work but effect apply doesnt work
hi there
another problem here is when we try to apply the effect to the enhancer image and download
the result its the same as the normal enhancer just for ur note its not working.
any solution pls help…
Regards
Hi there, I apologize for the incovenience this issue has caused. Would it be possible for you to provide the necessary screenshots so we may be able to further test and identify this issue? Thank you so much.
here is the sample
Original render
Enhancer render
Enhancer render effect ( look the same as Enhancer )
the result after effect should look like this
after the setting I do pressed save on that interfaced and the result still the same…
Regards
Hi there, I was able to try the same model and settings on my end and was able to achieve the effect that you wanted (please confirm). So in the “Effect” tab, you might need to select the Specific Content that you want to enhance, I selected the whole body of the Character (Including hair, shoes, face, etc.) and then proceeded to save after adjusting the settings.
Note: please ensure that the image you selected for AI enhancement is the original image, not the post-ai rendered image.
Please let me know if this helps, thank you.
oh, so we can’t just not select and apply the effect?
now it works for me but if we did not select but setup the effect the result still the same…
For this, indeed you will need to select the surface/object that you want to apply these
effect parameters since this feature was specifically added for the AI Enhancement to work on a specified portion of the image. Thank you.
