TEXTURE_STAIRS TILE MATCHING PROBLEM
Good afternoon, I have a problem with aligning the texture. On the step, the tiles do not match up properly, as shown in the picture. The texture was downloaded from the D5 library, and it is called I-shape Granite tile.
Hi @janachibraco
Have you tried enabling Tri-planar?
  • If tri-planar does not suffice, then I think changing the texture from your 3d Modeling software just to differentiate this portion would be a better option, since you’ll be able to control the texture compared to having it as a monolithic material. Of course, the material should be the same, just the material from your 3d Modelling software should be different.
