Texture scale resetting
I have a texture that keeps changing each time I re-open D5. I am syncing from Revit too, but each time I sync the model it doesn’t reset, just the first time when I get started. This is a street texture that I set a separete UV for the reflectance, not sure that has anything to do with it because both UV’s are changing when I open the model.
Hi @tyler
Can you send us a video recording of the issue? So we can confirm the full process.
  • Where is this file located? Is it in your local path? Or in the server path/cloud storage?
Of course I make a video and the problem is not occurring. I don’t think it happens every time, but I think it will happen again.
My D5 file is on a mapped network drive, on another computer connected by an ethernet switch. My Revit file is in BIM 360 on the cloud, but I think it makes a local copy each time you work on it.
I’ll come back here if or when it happens again.
