I have an issue mapping D5 texture on Rhino mesh object? The texture appears to be completely broken. How can I fix this issue? I’ve attached an image showing difference in texture mapping between mesh and a standart plane.
If the issues persist, can you send us your Rhino File so we can troubleshoot it on our end? You may send it to support@d5techs.com and have it titled ‘Clov-Forum Texture Mapping on Rhino Mesh Issue’
I’ve tried different mapping variants and the situation appears to be better. Thank you for provided soultion.
I have one more question: why when I import my Rhino model via D5 LiveSync, the scale of textures appers to be wrong and quite large, so I have to manually adjust stretching the UV in Rhino from around 7 to 10 times. This isn’t a huge problem. But I would like to know if maybe I am doing anything wrong. Millimeteres units are set up in Rhino and in D5.
Thanks for the update. Regarding the other question about the scale, does this occur only when using D5 Livesync? Have you tried importing it via D5A? Do they have different results?
Can you show us which version of the plug-in you’re using?
If you’re willing we can test the texture and model that is causing this issue. Let me know.
Unfortunately, we haven’t been able to pinpoint the exact cause of the problem at this time. This may be something that is currently not supported hence, the reason why there are various issues. Nevertheless, Please know that we are continuously working on developing our plug-in to address and resolve various problems, and we appreciate your patience as we strive to improve its stability and functionality.
Anyway, thank you so much for your effort. The software you provide is already amazing and the fact that you are still constantly developing it, really makes an impression.
