I’m working in a pretty large project and lately it’s been showing some materials like the one in the photo. Is there any way to refresh or to solve this problem?
Hi bro, try deleting the Base color map, then Ctrl+Z to undo it and check the result.
Also, you may need to check the video driver version on your computer.
To confirm, this texture and material is the one called White Rough Wall from D5 Library, right?
Yes, in this case it was the White Rough Wall but it happens with other materials too. Sometimes the error disappears after some minuts and other times it’s necessary to replace or delete the material.
Another tipe of error i’m experiencing with this file is that sometimes the texture appears in low resolution, like blurry.
I imagine that all of those errors are caused due to a very heavy file (11,4GB). It hasn’t happened to me before, and this is the heaviest file i’ve worked with.
yes, I have the same problem all the time, sometimes the textures look broken and sometimes the textures are blurry as a result of rendering.
